TwinTurbo.NET: Nissan 300ZX forum - Re: Its actually a check valve not the jet
Tech@EPR
on January 08, 2013 at 5:05 AM
posted by ZXoltan
on January 07, 2013 at 08:27 PM
only the diameter of the check valve overall in dimension is different the valve itself is the same. Don if you want to restrict more oil you'll need to machine or have a pill made that has a smaller orifice and press in like factory.
Ep Racing
Create Your Badge
if doing an engine build does the year of the TT block,crank
craigz96tt (SC)
10:56:47 01/06/13
It's going in my 96 without VCT so ill have to put half moon
craigz96tt (SC)
12:14:40 01/06/13
I have all the vtc stuff if you need it. (n/m)
TriniTT
19:21:38 01/06/13
I think I'll just do the half moons cuz 96 had 20 less hp
craigz96tt (SC)
19:34:06 01/06/13
Actually there is special hardware that goes back there
ZXoltan
06:54:52 01/07/13
I'll msg you when I get closer to doing the build (n/m)
craigz96tt (SC)
13:55:23 01/07/13
If you're going to all the trouble to build, I'd add VTC.
TriniTT
11:05:25 01/07/13
Re: I thought the 20 less hp was merely a rumor
Zeke21
08:39:59 01/09/13
year doesn't matter (n/m)
aliaZ
14:35:58 01/06/13
Thanks Don (n/m)
craigz96tt (SC)
14:37:40 01/06/13
There are some subtle differences between earlier and later
ZXoltan
07:02:29 01/07/13
I wasn't aware of changes in oil jet size
aliaZ
17:21:13 01/07/13
ZXoltan
20:27:39 01/07/13
Re: Its actually a check valve not the jet -
Tech@EPR
05:05:37 01/08/13
BDE Link
thumper (Los Angeles)
20:50:57 01/10/13
